1 - 8 of 8 Posts
AMG's 9 inch rims have a zero offset, so I highly doubt an 11 would fit a stock car.
According to Bruce 17x10 rims with an offset of 17mm will work for the SEC. I'm not sure how different the SELs are, if at all. If they aren't different 9's with 11mm offset should work.
I have 18X9 rears with an offset 35, and 20mm spacers, so net 15 offset.
Will 9 x 16 et 11 fit on the back of a 420sel?
9x16", ET 11 will fit fine, provided your rear suspension is in good shape (no worn bushings, bearings in good shape, springs and shocks in good condition).
I have the 3-piece AMG rims on my car and they're 10x17", ET 17 wearing 275/40 tires. I get slight rubbing against the inner fender under full suspension compression and had to roll the fenders to eliminate rubbing there.
If you put 255 (or less...) width tires on those rims, you shouldn't have any issues.
1 - 8 of 8 Posts
