1 - 8 of 8 Posts
1997 E420
if it's AMG monoblock Aero II front Wheel Offset: +31mm, tire size: 245/40-18 and rear Wheel Offset: +35mm, tire size: 275/35-18 Then yes ! I installed on my e420 without any problems [:D]
03 E500
I installed AMG Monoblock 3-Piece 8x17 wheels on my 97 E420, and these were taken off my 97 SL500. The Offset is 32MM, and they give just a slightly wider track and a more aggressive appearance when mounted on the E. I have seen other people mount AMG 18x9 from the SL onto E-class without any problem!
Tom.
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
Check to make sure the bolt sizes are not 14mm instead of 12mm. The offset on the SL is different than the E.
E420
RE: will 2004 18" S500 rims fit on a 97 E420?
Thanks for your reply.
What about 18" rims from a 2004 S500? Will they fit a 97 E420?
Ed
E420
RE: will 18" S500 rims fit on a 97 E420?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7967285656&category=66484
I am thinking of getting the 18" Mercedes Appearance Pkg. Wheels that came off a 2004 S500.
Will they fit my 97 E420?
Ed
I would say NO. The S-Class offset is different. The tires are too large.
96' E320
The bolt patterns are slightly different between the different mercedes models (chasis). You can always look up the different dimensions for each mercedes model on site's like Tire Rack. Good luck
1 - 8 of 8 Posts
