99 S320
I really like the 04 5 spoke wheels from the sl500 they are front 18X8.5 and 18X9.5 rear offests ET35 and ET40 is there any one that know if they will fit a 99 s320 w140 and can you recommend a tire size
SL500, CL55, E350, E320
Don't think the SL has 35/40 offset on wheels!? Besides, I wouldn't recommended because the wheels will stick out a bit too much.
99 S320
They are stamped et35 and et40 so that is correct. can I use spacers or is there no way of making them fit? Thanks
If the wheels are already sticking out, how are you going to use spacers? (to stick out more? [:)]). It is not impossible to put those wheels on W140 but in the long run, I would not recommend.
Having said that, if you have time and money, you can try it out. In the worse case that it's not working, you can always sell back for a little lost.
agracyal - 3/30/2005 11:48 PM
Are you sure these came from the 04 SL (R230) [?] ... I found it strange [V]
