yes - 88-320 in the FSM lets you know exactly. Loosen the adjustment of the cable to relieve tension first. The rest is quite simple.
An add on comment - after you replace cleaned latches and attach the cable, add two flat washers to the DS latch on the hood itself, one on each side. You are lengthening the hood latch to account for wear of the mechanism you just cleaned. Mine took only one on each side to catch sooner, you may need more so have a few. Adjusting the stop after you are done may be required but we are talking about fractions of MM here with washers.
I thoroughly cleaned out the old grease from both latches. Then I lubricated them and they are now re-installed. The hood opens easier but not effortlessly. When I lower the hood to a few inches above the body and let it fall it locks into place (most of the time). The left side (driver) doesn't always lock. I adjusted the hood height pins on both sides and improved the situation but again, not perfect. Today I am going to try adding washers as you suggest and see if I can get things perfect.
As a side note: I looked up the cost of the two latches and just about fell out of my chair. The two new, MB discounted parts, cost $1,000. Yes, they are much less expensive on eBay. This absolutely convinced me that I will completely disassemble my parts car next Spring and keep everything in storage. I plan to get every wiring harness, latch, pump, etc. possible removed, cleaned, then labeled and stored. I am looking forward to that project.
