fuel pump? is there any constant buzzing noise with contact on ?(do not start the car, just turn the ignition key to one step before starting). "healthy" buzzing for several seconds is ok, it means the pump(s) is ok.
fuel filter? replace it anyway ....
spark plugs? so cheap thing to replace it.
fuel pressure regulator (under the hood). i do not know anything about it, but its name tells everything.
rotors and distributor caps
vacuum and pressure leaks in the hoses under the hood
wires (engine wire harness, spark plug wires ...)
ETA (electronic throttle actuator), but this can be checked after all things above.
That is basic ... You must be aware that fault codes cannot be found out for many crucial parts of the car, for instance spark plugs.
