'01 SLK-320
Okay, I'm not claiming to be a budding F1 driver here or anything, but I do consider myself to be a decent driver with fairly decent fundamentals like heel-toe shifting. I can do it very smoothly with my other cars but for some reason in the SLK it almost always comes out sloppy and feels like I'm WAY overdriving the car - not smooth, silky and graceful like it's supposed to be. A lot of it seems to be the sensitivity of the brake pedal - it's very grabby and this tends to make the braking action a bit jerky (getting better w/ practice, but still very difficult to get "clean").
Suggestions? Thoughts?
Anyone else have the same problem?
'00 E430 Sport, '01 SLK320
I don't have the problems you described with the brakes. MBCA racing rules require a brake fluid change within 6 months of an event. So I tend to have the brake fluid changed more often than the recommended 2 years.
Down shifting through the gears the rpm increase required is not the same between the different gears. This takes practice. I have the best peddle feel with my well warn SAS shoes.
Hope this helps. :cool:
Regards, John
