1 - 20 of 29 Posts
see my signature.
I am curious to find out who has the lowest W124....
I propose that we have a contest. Measure the height of the bottom of the drivers side front door handle from the ground, and post up your result.
I will measure mine today after work, and post it up... :)
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Perhaps measuring the lowest part of your aluminum oil pan would be appropriate
Depends on the week
wrong forum justin lol
this place is anal retentive when it comes to these anything not factory
That's not as easy as the door handle.
30" on the right side of the road crown. :thumbsup:
94 E320 5 spd conversion
If I make a fist, that height of 4 fingers will just fit under my front crossmember (87 300E). Of course I have to be very much aware of box turtles and beer cans.
Black on Black S124 Estate and White A124 Cabriolet
This could be a legendary thread on some forums, but not so much here. I believe I know the winner and his car has a rare set of 2 piece wheels.
Cruise Control
Perhaps to win this contest, one might run with bags rather than springs.
For the record, I like lowered cars. I drive lowered cars...one even with cut springs (gasp!).
300CE-24, W204 C220 CDI, W210 E55 AMG, W124 300TE, W163 ML270 CDI
Does it count if you load it up with your entire family in the back seat, and leaking shock absorbers?....
Depends on the week
bags are cheating though.
so where are the measurements?
is everyone afraid to go against a factory sportline 30"? :D
Cruise Control
29.25" on the sedan, with 8" cut (linear) S124 springs. The rear needs more cut, so there's a pretty significant rake. The wagon with H&Rs still doesn't have an engine installed.
I think your coupe is at a disadvantage by using the door handles as a point of reference, since they're further back on the car, and thus if there's any rake at all, you'll measure higher.
Depends on the week
Didn't think of that..
I went out and measured a stock 300TD at the handle and it was at 30.5".
Maybe the front fender lip (since they're pretty much the same across the models) would be a better alternative to the door handle.
see my signature.
Discussion Starter #13 (Edited)
Hows the top of the mirror work?
Doesn't matter to me.
a point on the door mirrors should be the same for every configuration...
What about the classic measurement, center of wheelcap to fender?
see my signature.
Discussion Starter #17
I can measure center of wheelcap to the fenderlip.
This would be more fair, as it would not take into account the height of aftermarket wheels/tires.
I propose two measurements...
Centercap to fender lip, and top of mirror to ground. You also need a picture of the car. :D
money pits of various forms
I know I cant fit a low profile jack under my car anymore. I have to support an arm, lift it a bit and then get a low profile jack in.
see my signature.
Discussion Starter #19
lol, thats like my car.
i have to get some friends to lift it a little bit to slide the jack under it. o_O
1 - 20 of 29 Posts
