Current, 90 300CE, 92 400E (Sold 95 E320,70 250C, 91 190 2.6, 91 420 SEL, 95 300D, 87 TD)
Hello!..Who has the Best price/Quality for ignition wires cap and rotor. They seem quite pricy :eek: Q2.. If the wires seem OK can I get away with just a cap and rotor? Q3.. What else should I replace while doing a general tune-up? These are the things I've done OVP,crank position sensor (front),air pump, water pump, belt plus tentioner and shock, various hoses and pressure bottle, plugs (OEM Mercedes),fixed broken vac hoses,changed oil, struts [email protected], tie-rods plus I need tires real soon.
The entire ignition system including the coils is considered consumable and is generally due for overhaul every 100K, with plugs every 50K.
Thanks... I didn't know about the coil.
