1 - 12 of 12 Posts
04 4Runner V8 Lt, 05 SLK 350, 08 BMW 328xi Coupe
05 SLK350 with 9000 miles. I just noted that there is a whistling sound from the engine. The sound would get louder and higher pitch with the RPM getting higher.
Does anyone have the same problem or it's normal?
'06 SLK 350
whistling or whining? I had a idler pulley bearing starting to fail that made a noticable whining sound that changed pitch with RPM.
SLK55,CayenneS,XKR
Wimbledon_SLK said:
Hi, I have the same noise, apparently its the supercahrger in my case , going in for repair in 4 days, will keep you updated.
P
Hope you get it fixed as soon as possible, any reason why it is malfunctioning?
2017 GLC 300 4Matic fully loaded... but for the heated steering wheel. Stupid previous owner! 😠
As a test, and, if you are mechanically inclined, you can remove the serpentine (accessory) belt and fire it up. Give it a few shots of gas and see if the noise is gone. Then you will know if it is a tensionner or idler (or if it is even belt drive related.) You can run it for three or four minutes, maybe a little longer, just look out for the engine temp. The only problem you can get from this is overheating if you are not careful, or battery drain.
Discussion Starter · #11 ·
Here it is....
I got my SLK350 back last Thursday.
This is the job list,
Engine noise, lcated, 272-202-08-19 sheave pully
guide pully a - v belt, replace
replace upper idler pulley c/s .....
However, the problem is ... the noice is still ...
a high pitch noise change with rpm tho
2006 SLK280 MT
lucky6600 said:
Here it is....
Join the club. The very same part number was replaced in my 280 and it also didn't solve the problem. Another piece of info on the dealer invoice was "Check and found MBZ Bulletin P-B-13.22/01. Applied. Replaced upper guide pulley to eliminate noise". It seems those dealer mechanics tend to browse the service bulletins and apply whatever they find rather than trying to find the actual cause. I was told there are EIGHT pulleys in that engine. On mbslk.de, there were at least two reports from guys who had to get two pulleys replaced before the problem went away.
1 - 12 of 12 Posts
