Some of you might remember I did a transmission rebuild a while back. The cause of the initial failure was the pump and the pump bearing. When it failed it started leaking but there was no noise coming from it. Since then the trans has been great. Until -
A week ago the trans started making a strange whirring noise when decelerating. The noise is definitely worse when cold but is always present. It is most apparent between 20-40 miles per house when letting off the gas. The sound changes with speed and doesn’t matter if the trans is in D or N. That makes me think it’s either on the output shaft side or it’s the propeller shaft center bearing.
I’m hoping it’s not the output shaft carrier bearing or something close to the middle of the trans. Could a bad conductor plate or any of the plastic values on the control body cause the sound (I didn’t change any of the internals or springs when I did the trans, I took everything apart and all of the components seemed to be in good shape, I figured if something went bad down the road I could change it). Does anyone has experience with this issue? Or an idea of anything to test. And does the trans axel sound like it’s coming from the center of the car or is it closer to the rear? And I’m trying to figure out if driving around is making it worse. I’d really hate to blow this thing up again.
I haven’t checked the trans with a scanner but there is no CEL. The only thing that might be off is it seems like the car revs slightly higher when going downhill than I remember but I’m not sure if that’s something that it’s always done and I’ve never noticed. There are no shift issues with the trans now so part of me just wants to leave it alone if it’s nothing major.
