Only at start and when engine is cold. Gear in P and I was gently revving the engine couple of times up to just over 1000RPM before shifting into R. I was touching nothing other than gas pedal
The whine came from engine bay passenger side. Sounded like a metal pan or something hollow was reverberating to a specific frequency. It only happened between 900-1000RPM.
Any ideas?
Could a car be designed like Sea-Tac Bridge that it can fall apart at certain harmonic frequency?
Moderator
1991 500SEC 55K mi. 1987 560SEC Now 153K mi. 2020
Hi naomilla,
Two words come to mind: Heat shield.
MBL
Depends on the day!
Will it continue to make this noice repeatedly?? Chances are it is a heat shield, most likeley the one surrounding the pre-cat.
Jonathan
Since I drove by the garage I take my car for major service work (anything other than oil change and other *very* minor repairs I am capable of), I popped in and told them of the symptom. Sure enough, it was the loose heat shield. The mech recommended removing it but I just asked him to retighten it for now ('Let me think about it' was what I said).
Any adverse effect from removing the heat shield?
Heat shield is to protect the transfer of heat to other locations... Duh! (J/K) Most cars can live without em, some can't...
MasHiMarO - 2/25/2005 4:23 AM
Would you consider W126 (560SEL) to be in the former or the latter category. I wasn't sure and that's why I held off. Some time ago in this forum, one of the Canadian folks posted an experience where he went through a puddle and had loose heat shield become entangled - I don't want that to happen to me, and if the car can live without it, then I'd take it out as if it is an inflamed appendix.
Moderator
Hi again, naomilla,
In addition to shielding floor pans & various components from high exhaust temperatures, the H/shields perform another function not often recognized. Usually located upstream of, and close to both the Ox Sensor & Cat Converter, they ensure the rapid & sustained heating of those two items, thus providing more efficient operation, resulting in reduced emissions and overall smoother, more powerful engine operation.
Who knows; when tight, they may provide the added bonus of sound reduction inside the car as well? :eek:)
That said, years ago when I worked as a tech, I've removed & tossed out rattling heat shields on more than several occasions.
My 3 cents. MBL
