Hi
Anyone who knows what kind of transmission the w210 E55 AMG 4matic has? Only info i find is that the E55 4matic is built on the E430 4matic, but it doesn't state which transmission is used. If it's*other software on the 722.699 which E430 uses or no difference*at all.
I've been reading through all the transmission codes that i can find for the w210 and there is no mention of a E55 4matic transmission.
Swapping a 113.980 E55 AMG*engine into my E430 4matic and just want to be sure that the transmission will work proper
-Peet
I have considered doing the same. All I have read is it should all work. Btw, the only difference I saw on the 4 matic transmission is the transfer case which bolts to the output end of the transmission. Therefore I surmise one could use the E55 transmission and engine.
Sent from my iPad using Tapatalk
