Hi I have got the laser injector cutter pack 4597 it comes with 4 cutters....
Do I use the 15mm flat cutter (17 / 19mm body) - general use
or the 17mm flat cutter (straight 17mm body) this seems tight against the base)
It says the 19mm / 17mm cutter is for the merc CRD, and the 17mm section is not long enough when compared to the injectors for the CDI.
The washers I have are 15mm and the base of the injector is 15mm, but the lower body is 17mm???
For testing 'uniteddiesel' recommends making up a washing up liquid solution to put round the injectors to test.... is this okay will it not cause damage??
Thanks for the help
Vito 280 ,ZX7r,gsxr 750, ,Z650 Cafe ,Benelli Tornado.Ford consul , Ford Pop , ,Chevy Astro,Dog,Wife
Cant remember which size i used..BUT make sure you use plenty of grease on the cutter to catch the swarf, and keep cleaning it and re-applying new grease.....washing liquid solution is fine..it'll show any leaks by blowing bubbles....theres a plumbers solution too we use for testing for gas leaks....same thing really....
Thanks will test injectors once they are in, the 15mm cutter seems to fit much better.... so may give that a go.... will use plenty of grease....
