Let's keep working on the GL450.
There is no warning message yet, but when applying brake and when the truck is moving slowly, a weak high pitch sound can be heard from rear. maybe this is a sign of needing new brake pads? The GL450 has 51k miles on it and have not got new set of brake pads.
Searched online and found some tutorials and videos on replacing the brake pads and rotors, so far I got the following points:
1. better to replace the rotor together with the pads
2. it's not difficult to replace them
now the questions are:
1. what brand/type (websites) rotor and brake pads do you use/recommend?
2. some people mentioned that OEM stock pads is more efficient in braking than Akebono pads. although OEM stock pads produce more dusts and are dirtier. is that true? Akebono seems a good brand, I've used them before for other cars, and they perform well.
Thanks a lot.
Thanks a lot.
