99 Clk 430 Lorinsor springs 19" Oz Opera/ 00 ML 320 19" Moda R6
i have just installed a new head unit into my 99 clk 430
now my only problem is where do i run the wires from the deck to the trunk where the amp resides???
how do i remove the passenger kick panel and the metal side sills as well?
any help is appreciated.
will post pics once everything is complete
86 560SEL
The sill, you just give it a good pull and it should slap out. Or you could just pull the...
The sill, you just give it a good pull and it should slap out. Or you could just pull the carpet and run the wires behind it and then spray some glue on and put the carpet back in place. Going to the trunk is a little tricky, you need to go thru the backseat. I don't remember how people did that on my car. Good luck.
