I really hate to flame on you but that's the most irresponsible response I have ever read on this forum. Just shove the jack anywhere under the car and pump????? Yeah right!!! Are you on some kind of medication or you just want to piss me off???lvfjmbusa said:just shove the jack under the car and pump. Mercedes have very stiff undercarraige
You probably don't have an owners manual because if you did even your half dead brain would have noticed that the owners manual doesn't tell you where to put floor jacks. And even if it did, I'm sure it'd not say to put it anywhere under the car. Have you even read the owner's manual? Do you even know what it looks like? If you can find me the page it says to put a floor jack anywhere under the car and go on with your business I'll apologize publicly on this forum for flaming you. But until then, take your retarded comments somewhere else. I don't get angry much at people suggesting anything on the forums but you just crossed the line in my book and I can't help but lash oput at you. I can't believe you even have the balls to reply after you completely suggested something so unsafe in your original response. You probably don't even have a 210 car and just think that throwing any response here is OK.lvfjmbusa said:If you have the owners maual it shows you where to put it. Or if you look under the car you will see the big rubber pads.
In my opinion if you dont know how to jack up a car, you shouldn't be working on it
OK, I know what you're talking about. Unfortunately you don't understand what I'm talking about and please forgive me if I was harsh earlier. I'm not talking about changing tires. I have to do a brake DIY and even though that requires taking the wheel off, the car still has to be supported adequately so that as one works on the brakes (there's a lot of hard torquing required), the vehicle is still stable and will not tip off on the stands. The regular jack for changing the tires will not hold the car stable enough for this operation, hence the need for a floor jack. For a lot of vehicles, the recommended placement location for a floor jack is usually not same as for the tire changing jack. Infact, for the 210, it's not even possible to locate a floor jack where the tire jacks go. The floor jack would have to be placed somewhere under the car's frame, a very solid location, otherwise the vehicle may buckle under its own weight. If, for example you place the floor jack under the driver's side foot area, guess what, the darn thing will make a pretty nasty hole right through the floor. So, I hope now you understand why I flamed you for suggesting what you did. Friends again????lvfjmbusa said:It tells you how to install your spare tire in your owners manualy, when you change a tire you need to jack up the car.
I give up!!! I'll talk to my SA tomorrow. Thanks anywaylvfjmbusa said:Well this is what I would do look where the jack goes in the side of the car, then realize a floor jack can not go into the hole, then look under the car in that area and locate the rubber pad under the rocker panel and proceed to jack
true, same here..raymond- said:good lord, that MB jack is for emergency use only. when performing maintenance
and mods, i only reach for the floor jacks. i jack them up at the bumper pad
high enough, then slide the jack stand(s) in. when operating underneath the
car, redundancy in car support is important.
