1981 240D
All, On a previous post it was recommended to me that I might want to try replacing my rack dampener bolt (in the IP) for curing some starting issues. I have looked all over the performace products catalog and autohaus az and cannot find it.
Where do you get this thing from??
Thanks.
1981 240D
hmm, good point. it appears that my 240d doesn't even have one. shoulda thought that thru better i spose!
i already did a diesel purge and checked the glow plugs. Everything else on the vaccumm system seems to be working fine. I guess one thing I need to check is compression, too.
You could try adjusting the valves. There's only a few things and then you're out of stuff to test/tune with these rigs ;)
1981 240D
Discussion Starter · #5 ·
Thanks for the suggestion Stabmaster, unfortunately I already did that. It did help with making a smoother idle, but that's about it.
Yeah, that's good and bad. Good for obvious reasons and bad that since I've done most of the simple stuff, there's only serious things left (or I just live with it, which might happen until I get out of school and get a job!)
