93 300E 2.8, 79 450 SLC
Where is windshield water pump located in the 1993 w124? No water coming out from the washer injector and I can't hear any pump noise. Fuse looks ok. I guess the pump is gone and need to be replaced.
Thanks.
W124 Moderator
The pumps (2) one for the windshield, one for the wipers are located on the front side of the washer water tank, just behind the right headlight. Pumps are about $12 ea. You'll want to replace the rubber gromets as well.
Jayare
I see it now. Thanks!
00 W202, 04 955 S, 08 e90
pump seize over time. just replace it and gromets and you are good to go. but also depend on the tubes connected to pump, i had to cut a little bit off as it was crakced at the end hence getting a leak. bought new clamps and resealed back and good to go.
