In a 1999 E320, where exactly is the amplifier? Someone at an audio store indicated that it might be in the truck on the drivers side. If so, exactly where is it and how to access it?
Could the amp be the source of left channel sound distortion as the Becker 3302 radio checks out to be working 100%?
thanks
W221 & Audio Moderator
2013 S550
Check the phone bulletins on Paul's website at http://home.earthlink.net/~phdwebsite/phone_bulletins.htm
Despite being labeled phone bulletins, they show the locations of other equipment and how to access it.
Obviously the amp, or bad wiring, or a bad speaker could be the problem.
the sound amp is located in the trunk on the left side. to get to it you need to remove the left inner
trunk liner (2 plastic rivets holdingit there)
its pretty much located on the wheel well where the base of the trunk spring assy connects.
