is it behind the battery with the 10a fuse in it? is the ovp gives power to the cold start valve? what else it does?
thank you guys for the help.
mine has only 1 fuse ,but the one i'm looking to buy has 2 fuses. will it still be ok if the numbers match?
Discussion Starter · #5 ·
the number on the one on ebay is: 201 540 37 45
he says it's good for 300e 92 and up. what do you guys think?
There are 2 types of OVP, the one with one fuse, and the one with two fuses, i`ve heard that you can use the one with two fuses on both, but i`m not sure about it.
Also speaking about Euro cars
2011 GL 320 CDI, 2004 E320, 2000 C230, 2004 Toyota Sienna
I also bought an OVP from ebay and has two fuses. Mine has only one so am reluctant to use it. I have cold start problems. Was waitinf for some one with similar problem.
