none
Tittle! I can't find it, going to try to ground out the ASR and see what happens. It's stuck in limp home mode (LHM) I doubt this will fix it and I suspect the ETA is the culprit.
Honestly I'm not sure if it's even LHM. When at 1/4 throttle the car goes pretty decent but if you mash it, the car bogs down really bad. It's possible it just needs a tune up! Yes the check engine light is on, going to take it to the dealer later. I'd love to be able to scan it myself, but I'm not paying over 1,000 USD for a scanner!
1992 600SEL Graymarket
The port you're looking for is under the hood behind the drivers side wheel well. Which state are you in? I have a 92 600SEL in Delaware and did pony up the cash for the scanner.
