1 - 9 of 9 Posts
I have a 1992 300 SL. I am trying to locate the fuse that controlls the air conditioner. I was looking at the fuse box and I could not find it.
Where are the circuts that controll this. There seems to be no power going to the air conditioner unit
bruce
When facing the engine I was looking at the fuse box located on the back right corrner. I was a black box with a metal clip holding down the front cover.
Where are the 2 fuse boxes located. I only discovered 1
There is one in the trunk, but the A/C fuse is in the one up front, the one you've looked at.
Can't tell you the Fuse # as you have a '92 and I have a '98 and they could be different (mine is #17), but there should be a fuse chart in the lid of the box.
You can't change to new style fuses without major re-wiring to replace the whole fuse box. All you can do is to replace the aluminum one with copper ones of the same size, shape and Amperage.
1 - 9 of 9 Posts
