1987 560 SEC
My driver side presenter wont come out and continues to hum as though it was working. I dont feel like taking the whole seat out and panel to assess. I would rather just turn the thing off and stop the buzzing.
Anyone?
Thanks.
2012 CL550 4MATIC Coupe
To reset the SBP's, remove fuse #15 for no less than 30 seconds and that will reset the relay's. Unfortunately, Fuse 15 also powers/protects the Central Locking System; Anti-Theft Alarm System; Power Seats; Courtesy Lamps; Automatic Antenna's and the Seat Backrest Locking System. SO removing it disables all of those systems too. You do not have to remove the front seat, only the rear seat and it is very easy. Push the red lever under the bottom cushion and lift. Then just lift up on the back rest portion.
Getting the panel off is a task if you don't know how, but once you do it once or thrice it's comes off pretty quickly.
I have a spare set of presenters if you have an early SEC, for $100.00 if you need them.
