Can you help me locating the cold start valve "relay"on my 1976 Mercedes 450 sl . I look for it every where could not be found any where. Can you help please. thanks
1998 SL500, 1959 220S, 1970 280SL
That's true, but there is also a cold start valve, controlled by a "thermo time switch" that measures coolant temp and controls how long the valve squirts by supplying ground. They are both at the front of the engine.
1975, 280SL
According to the wiring list you don't have a cold start relay per se. It's a combination "relay, fuel pump/warm up control". Should be under the dash on the passenger side. Look for the relay with a large violet lead.
