I'm about to change my oil again and I need to definitely know where to locate the coil so that I can disconnect it before the live re-start after the oil has been changed. This is from a previous post:
Yes, this is part of the oil change process. I’ve posted about this in the past. A mechanic should certainly do it to avoid possible liability in the event of engine damage in his shop – DIY as a precaution. The damage described, however, is extremely rare but the coil should be removed and the engine turned with the starter motor to bring up some pressure to reposition the tensioner before a live start.
