1986 560SL, 1993 Isuzu Bighorn (RHD & Diesel)
Could someone help me ID these wires/vacuum lines?
2639918
^^ This loom is on the passenger side, it has a red and black wire under the loom.
2639919
^^ These wires are on the drivers side.
2639921
^^ This is on the passenger side, is a wire missing here or just a random fuse?
2639920
^^ This vacuum line is behind the glovebox, not sure where it goes but I noticed my recirculation switch has 3 holes with 2 lines going in it. Maybe this goes there?
2639925
^^ Does anyone know what this black cylinder does? The wire is disconnected and not sure if I should reconnect or just leave it alone?
R/C107 Moderator
Pretty sure the fuses are for the alarm system. The missing wire is normal.
The vertical cylinder is the heater valve that connects to the horizontal cylinder, re circulation / auxiliary pump. The The disconnected wire probably goes directly below it.
