1 - 14 of 14 Posts
Hi so I just finished cleaning my EGR valve and couldn’t find where one part on the egr plug to, the one circled on the first picture. Second thing I randomly found theirs 90 degrees angle tube. Just sitting by the battery 2nd pic. Anyone know please help out, thanks in advance.
The second photo - It vents to the atmosphere - does not connect to anything.
Technically called 'air admission'
sorry, i didn't see this reply, thanks guys for all the help. the car still feels like it wants to die at red light, i might have to change the MAP sensor.
Have you cleared the codes and then take it for a spin?
Check for codes after.
Clean your MAF? takes 5min and let it dry.
i did that too, i drove it for 20 minutes in highway. i've replace the Crankshaft sensor as well a few weeks ago, i dont know what else can cause it to want to die on me at red light
You never answered the other Q.
Did you clear the codes and re-scan?
i did clear the code. but i haven't checked the codes after the drive.
CPS - is it oem? or generic?
If you have no CEL or codes, could possibly be your motor mounts. Have you ever replaced them?
What's the mileage?
Do a search on utube on testing if it's the motor mounts. This can mimic a "stalling effect".
EDIT:
while your at it...
Check all your vacuum lines for cracks, etc.
Discussion Starter #12
What's the mileage?
EDIT:
while your at it...
CPS was OEM bosch brand same one i took out.
i have not replaced motor mounts.
milage is 247K
thanks bro, never knew motor mounts can do that.
1 - 14 of 14 Posts
