G
Guest
·It's a bit costly !! more
If you want the real thing, the whole assembly has <br>to be replaced. Bekkers Imports sells them for<br>$1,672.00 An alternative is bulb replacement but it's<br>not that bright.<p>If you check the W210 E Class board, there's a guy<br>there named JIMMY who sells them. Check it out.<p>John<p>: Where can i get XENON lights to replace my CLK Stock Lights? I've seen the Xenon lights around and they look very impresive. Does this require just replacing the bulb? Or is there more cost to it? thx!<p>
