1987 190D 2.5 Turbo, 1999 Mercedes Benz C230 Kompressor, 1986 190D 2.2 397,000miles
I am tired of having problems with my 190D 2.5T. It needs a head gasket now ( uses coolant), smoke pretty bad, basically to much to worry about. So my question is where can I find a new engine? (used of course, also any other ideas for engines)
92 190E 2.6
check criagslist and junkyards, but that was not a very common engine. you are probably better off having yours repaired. It would probably cost about the same either way
1985 190E(SOLD 04/14/11) - 1986 190E - 1986 190E 2.3-16
+1. And by doing that you know for sure that your engine is brand new. Buying an used one is no guarantee of solution.
1992 190E 2.3 8v w/ '87 5-speed and 3.27 rear, 1966 Shelby Cobra 427 S/C, 2018 Triumph Bonneville
I've seen a number of 2.5 turbos in some 300Es in a couple of junkyards. If you're willing to do it yourself, you can save a lot.
Smoking...piston rings or valve guides?
