1 - 14 of 14 Posts
1996 S-500 white
Where Can I Buy CLIC CLAMPS For My Fuel Filter ?
My Dealer Pembrook Pines M-Benz Don't Stock Them :confused: Now That Is Pure Bull Shit
Help Me Out Here,, I Been All Over The Net With No Luck
Joe :Smoker:
1999 SL500 Sport, Black Opal Pearl, Helios Leather, Pano roof, AMG Aero2 18"Split Rims, Rear Seats
I dont like these clips at all. I actually did have one fail on my fuel filter a while ago. Just replace with good old jubilee clips or worm drive clips that have been tried and tested over decades. If they loosen off a bit with time you can give them an extra turn.
1996 S-500 white
But I Understand The Worm Drive clips Are Not Good For Pressurized Lines, I Might Be Wrong ?
Am I ?
Joe :Smoker:
1996 S-500 white
Discussion Starter · #5 ·
I agree with WayneG, those CLIC were used to save time/labor on production lines.
I Think I'm Going To Go With This Style Clamp
What Do You Think ?
Joe :Smoker:
NEW - FUEL INJECTION HOSE CLAMP - FITS 3/8" ID HIGH PRESSURE & HIGH TEMP FUEL INJECTION HOSE - CLAMPING DIAMETER FROM 14MM-16MM -
What Do You Think ?
Joe :Smoker:
That should work. This is the same type I found in my Porsche (I haven't look into what is in my R129 yet).
1996 S-500 white
Discussion Starter · #8 ·
1996 S-500 white
Discussion Starter · #10 ·
I dont get it, why use some fancy clips when a good quality worm drive is the tried and tested way to go.
http://www.benzworld.org/forums/r129-sl-class/1322178-supercharger-makeover-71.html#post2660849
Well I Guess Thats Just Me, But Remember The Clamp That Your Useing Has A Tendency To Cut Into The Rubber Hose , So Im Just Going To Be On The Safe Side, I Don't Want My Car Going Doen The Hyway In A Ball Of Flames
But That Just My Thinking
Nice Set You You Have
Enjoy It
Joe
:Smoker:
· Greek God of the R129
SL500-500SEL-190E
RKH:
Thanks I Found That Seller , But If You Look At His Sight, There Is No Way To Buy From Him, You Have To Call Him Or Email Him, And Might Sell Them By The 100's
Did You See Up Top What I'm Going To Use ?
Joe :Smoker:
All Mercedes used that clamp on the fuel lines for decades with out
any problems of cutting the hose.
Do you think that the new broom cleans better then the old?
Come on Joe. Hahah.
Regards.
aam.
1996 S-500 white
Discussion Starter · #12 ·
Come on Joe. Hahah.
Regards.
aam.
Well The Way I Look At It ,There Is No Harm In Putting On A Little Better Clamp, Thats Just The Way I Think Of It.
The Worm Type Clamps Might Be Just Fine, For 99% Of The Applacations, And I Agree With That 100% ,, But When It Comes To My Fuel Lines On This Fine Auto I'm Going To Go With A Tad Better Clamp.
Sorry If Most Don't Agree , But That Is Life I Guess
Thank You All For Your Input.
remember This It Don't Cost That Much Extra To Go First Class :p
Joe :Smoker:
Click-clip vs. worm-screw clamps
Am I ?
Joe :Smoker:
Very true.
In fact years ago my first European car needed some major work and I was so frustrated at dealing with these unique clamps (had never seen them before), that I changed all the clamps I could see with off the shelf worm-screw clamps you find at every local hdwr or auto parts store.
The coolant lines which have very thick rubber hoses weren't a problem, you could crank on the screw to get a good bite into the hose.
But fuel lines kept popping off when I least expected it.
Now, I'm not saying there is "no-way" to retrofit the funky click-clamp with your garden variety family tried and true worm-screw. Depending on the Pressure and flow rate, temperature near the fitting and most importantly, the shape of the metal FLARE on the filter, yea it might hold together.
But personally I'm going to air on side of caution and stick with the OEM clamps here.
1997 Mercedes SL500
Joe :Smoker:
All,
Seems to me things are getting a little too complicated.
Here is the source of the "improved clamps" as well as the ratcheting type which might even work better. Cheaper source and you can set the steel clamps with a set of diagonal cutters. You will, however, have to grind it off when you remove it.
I can also find the metric originals which actually do work if anyone is interested. (Maryland Metric) MARYLAND METRICS 'HOME PAGE' They are not just for production and have a very logical design when one is looking at easy removal as in the case of a fuel filter that gets changed routinely.
Find Hose Clamps At SmallParts.com
the screw type clamp is normally just not appropriate for the small diameters of the fuel filter and will in most cases be worse than not putting a clamp on at all because of the uneven shape that is created by the screw mount.
Regards,
George
1 - 14 of 14 Posts
