1994 Mercedes E320 wagons (2)
When I removed the transmission rear case housing earlier, this part called the oil pipe speedometer drive fell out. See item 44 in the enclosed diagram.
Now I am about to put the transmission rear case housing back on. I am kind of lost as to where exactly this oil pipe speedometer drive, item 44 in the above diagram picture, goes in? Someone said thats the oiler for the speedo cable drive, its held by the O ring and supported by the extension housing itself when assembled. Does this oiler pipe goes inside the speedometer cable somewhere? Anyone out there can help me out here? Thanks to all for reading.
Discussion Starter #2
I finally figured out where this oil pipe speedometer drive goes inside the rear transmission after removing the rear transmission case housing. I enclosed a better diagram that shows where the oil pipe goes in. See item #66 in the diagram. The position of the oil pipe, from what I seen in the diagram, should be in the upright positon.
Here the pictures of oil pipe speedometer drive in place on the rear transmission
before putting the rear transmission case housing back on.
