mercedes benz 500 sel year-1993
I have a 1993 500sel can i put 18-8.5 in the front and 19-9.5 in the rear with out having any trouble with the car
2014 CLS63S SB
Yes, I think so. In fact one thing I know you can do for a fact is put on 9.5x19 with 275/35s and 46 offset all round. With any wheel set up tho, make sure you get the overall rolling diameters close as 140s are quite sensitive to it.
But why would you want to?
1997 s420 (pearl black opal), 2005 c230k (obsidian black)
just make sure that the offsets are high, above 40 especially if you want wide tires in the rear.
Discussion Starter · #5 ·
my offset in the front on 18.8.5 is 25mm and the 19.9.5 have a option of 25mm or 53mm offset witch do i choose
the front is too low and the rear is a little high, that combo will not work. you need at least upper 30s in the front and mid 40s in the rear
for example et 38 front and 44 rear, if you use the right offsets you will also be able to use the widest tires possible for that size rim.
but 25 is way way too low of an offset for the w140.
