1993 MB 190E 2.6
Hello Everybody:
I have not spent much time on this board, you could usually find me over at the 190e board. I have a set of wheels that are OEM on the C class gasoline vehicles (16x7) with et of 37 and 112mm bolt pattern.
My question to the board is will these wheels work on an 82-300CD?
I thank you for the assistance,
Ripley
scripley - 5/15/2005 7:40 PM
Unfortunately those wheels may not fit as-is. 300CD wheels usually have to have an offset of 30 or less at 14". At 16x7 w/ ET37, you are bound to hit the tie rod bushings in the front wheels - best thing to do is trial and error. The rears may work but the front could be a problem - a hubcentric spacer could be the solution but you may need at least 10-15mm sizes. But the best and only sure way is to mount them and see (inside) if all is clear.
