I'm planning on new wheels for my CLk. What does the wheel offset mean and how do I know if a wheel will fit?[8)]
Wheel selection for Mercedes is very limited.
The offset is the measurement from the inside hub to the inside of the rim. Changing wheels can be complicated. Many have put 18�, 19" and 20" wheels on their car and live with the slight annoyances that they cause.
If your stock wheels are 17� going to a larger diameter is called Plus size.
Plus 1 means that you have increased the outer diameter 1 inch
Plus 2 two inches, you have increased the outer diameter 2 inch and so on.
The tire rack has a good online calculator.
If you plan to lower your car lower it first then pick the wheel size.
If you go any larger than Plus 1 you most likely have to modify the car somewhat.
For instance rolling the finders, or changing the spring pads.
The best thing to do is educate yourself so you know exactly what you are getting yourself into. It’s really not that much information unless you decide to go to the extreme. That’s when the problems start.
Best of luck to you,
Tim
