U500 with Unicat camper
Anyone have experience with decreased offset wheels on heavy Unimogs?
Specifically the stock steel wheels were 161mm, weighed 116lb without beadlocks. The 395s are about 220lb.
I obtained a set of Hutchinson MRAP wheels which are perfectly balanced unlike the steel wheels, 84 lb +~15-20 lb for beadlock. But they are only 90mm: 2.8” further out. Steering is perfect. CTIS works.
I am wondering about effect on hub output shaft bearings. Please note that the U500 (which I have) allows use of 495/70R24 XM47 (260 lb) with DW16Lx24 wheel (steel, got to be at least 130 lb). Which has 110mm offset when sourced from MB. So I am only 20mm over that.
But, load onto the axle is unchanged. With max load rear axle weight is 8000kg; close to GAWR of 9000.
Anyone have experience with this? 25000 miles with this configuration so far. I do carry complete portal parts.
'76 1300L,HE351CW,H15P Winches,Konis,Hydraulics,All Gears,10mm Plungers,Aftercooler,Lots of Littles
The moment of the wheels you have is less than the moment of the wheels spec’d. That would make me sleep OK, if I were you.
But generally I doubt anyone has any more experience with the setup than your 25k miles...
C.
