1994 Mercedes Benz SL500
Hi,
I know there is a lot of info on wheels on the site. But it gets confusing. I just want to know what offset range will work on my car using either 17 or 18 inch rims without using spacers.
17" the ET range is___ to ____
18" the ET range is___ to ____
Any help would be appreciated.
Thanks guys.
1998, SL500
There is a brake caliper on a side, so you need space for that. You can measure space between rotor and caliper yourself, anything over your caliper size will fit.
ET 27 + for the front i think should be fine.
94 SL320 98 SL500 99 SL600 07 SL55
Hi,
Thanks guys.
For 18" Ronal wheels you can do 30 8.5" front and 33 9.5" rear without spacers. If you want to space I use 10mm front and rear 15mm
00' E320, 03' E320T, 05' C230K
Discussion Starter · #5 ·
Thank you guys for your help. I bought a used set from an S-Class they fit with a 5mm spacer. Just enough to clear the brake caliper.
Bad news is that I didn't check them closely and found out that two rims are cracked.
