are all vito/vclass wheels interchangable or did the PCD change at any point? For example is it possible to fit 2003 model wheels to 2007 and vice versa...
PS if anyone has any 16 inch alloys going let me know...
Hi All, can someone help me locate the Relay and fuse location of the Air suspension compressor for my 2006 Viano
Air Suspension would not power on.
I removed the compressor unit and tested put 12 volts to it, it came on but only very slowly, we had just had the beast from the east it had bing...
Hi there I recently purchased a 08 vito well pleased with it but second gear can be slightly stiff to engage i notice this is a common problem with them and just wondered if there is anything that can be done to help or sort this problem?
Thanks Matt
Hey,
So it'll be a huge surprise but I've got some issues with my gearbox or it's command.
1st has always been a pain to engage, but since last week it's now 1st, 3rd and 5th. 4 out of 5 times it'll not engage, just rattle my gearbox like a can.. 2nd and 4th don't have any problem.
I've...
vito 111cdi 2008 cranks but wont start there is no air in lines low pressure fuel pump ok,There is 350bar at rail when cranking injectors checked ok back leak test ok,cam and crank sensor ok all other sensors checked ok. it sounds like it is going to start but it dont It does start with easy...
Lads I'm selling my conversion ...They have been off the van for a few months and theres a little surface rust on them...work perfectly and a HUGE improvement on the stock brakes and no need to change or alter the mastercylinder.
Brembo 4 pot calipers.
Brackets..fit straight on..
Discs...
