02ML320 & 06RClass (sold)
is it possible to take out the wheel center cap with the wheel is on. Want to replace the crack wheel center cap. Thanks for your input.
If you are throwing it away anyway, punch, or drill a hole in it and pull it out with a hook.
98 ML320 / 06 S2000 / 12 E350 BTC
since it's cracked already then just break up the rest of it and pull it out.
I would never pick from the sides risking paint damage to the wheel
C9H9N Offensive Odor Exuder
2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
A feeler gauge of about .020 will probably do the trick (it worked on ours). Insert the feeler gauge between the crack in the cap and wheel. Then give it a slight twist while pulling at the same time. It takes a little working but you can work them out. Once you get the wheel caps out a little, you can finish with a small screwdriver.;)
Discussion Starter · #5 ·
The thing is, even though only one is cracked I still have to change the other three. Coz you cannot buy one "brabus " wheel center cap only, right. So how do you maneuver the good ones to remove - just crack it per Kajtek1 instruction.
If you want to save the other 3 -consider removing the wheels for it and popping them from other side.
Good excuse to inspect the brake pads and clean the inner part of alloys.
Discussion Starter · #7 ·
Wondering if the Brabus wheel caps has different sizes. Looking for size from Monoblock IV, like the one from Chris 007.
