Current ? (Thinking GLC SUV) Previous 1998 E320, 2007 E320 Bluetec, 2008 320ML CDI
I replaced the brakes including rotors on my '08 ML 320 over the last couple of days.
Vehicle has 115,000 miles and were on the original set of brakes as far as I can tell.
The brake wear light has been on for a while and the RR set of pads had a sixteenth on the outer and an eighth on the inner. RF was also to the wear sensor though more than the rear. LF and LR had life left.
Couple of observations:
The passenger side bolts holding the caliper brackets were very difficult to remove compared to the drivers side.
May be a consequence of living in Michigan with winter salt.
Not sure, but I checked a couple of times to be certain I was loosening. Had to use a breaker with a 2 foot cheater.
Both front rotor keeper bolts had to be drilled out. Rears loosened just fine.
Front calipers require a 9 mm hex. Of course my set went 8 to 10. Grrr.
New MB brake fluid as well. The existing stuff looked slightly dark, but OK.
Question of the moment:
Is there a life expectancy to wheel bolts?
At this age would it be prudent to run a tap through the hub and run the bolts through a die to clean any grunge?
I had some resistance when mounting the wheels and I had not done anything to the bolts or wheels. I ran them in by hand and wrench - no power tools.
Appreciate your thoughts.
Skippy
Skippy
