1 - 1 of 1 Posts
So, i have had an ongoing issue with the wheel bearings in this car. before the car was in my hands, i was told that it was replaced twice relatively close to each other(dealing with the right front). Im not sure the exact mileage inbetween them but i know it was nowhere close to what it should have been. when i got the car i put aprox 6000 miles on the car when i had to replace it again. Now maybe 5000-10000 later, i need to put another one in it. Now i did figure out about 3k ago that the slider pin on the brake caliper was stuck, would that cause my issue? would that cause the grease to boil out of the bearing causing repeated failures? also, now with so many bearings going bad, should i replace the hub? anybody else had an issue similar to this?
1 - 1 of 1 Posts
