Could they just have been repacked? Either way, I'm trying to figure out why the hub would need to be replaced since the outer races are replaceable.
Good catch. The outer race does look thinner than the other picture. Maybe the OP can let us know exactly what work he did. Maybe he swapped bearings without putting in new races?I see that the washer is in fact there, Thanks for pointing that out. What I noticed while doing that is that the wall thickness of the bearing is different between the two photos. Could there be a POS bearing on one side?
If it were me I would replace the bearings and races and see what happens. Bearings are probably the cheapest finely engineered item you can buy today.
Good to know I'm not crazy. I asked all the same questions in post 5.Is the threads on bolt holding retaining nut loose/stripped? That is the only way the thing could come loose.
OP - are you saying that entire locking nut unwinds itself? if so the clamp is bad.
if something other than please clarify.
alt theory is the bearings are incorrect.
OP are you adjusting bearing with a dial indicator or just guessing? .01mm end play is very small....
The bolt holding retaining nut was not loose.Is the threads on bolt holding retaining nut loose/stripped? That is the only way the thing could come loose.
Hence why I recommend (for the 3rd time) to put in a entire hub assembly. No need to reinvent the wheel (pun intended).... unless the entire part is bad is some fashion.
When you say hub assembly, do you mean the clamping nut and bolt?Hence why I recommend (for the 3rd time) to put in a entire hub assembly. No need to reinvent the wheel (pun intended).
Do you think so .. Because if you do it you dont need all this equipment .If the OP wants to solve his problem he only needs this:
Magnetic Base with Fine Adjustment and SAE Dial Test Indicator with 0.0005: Resolution (half a thousandth), 1" Travel, Accuracy 0.001" per 1" Mag Base MBDI: Amazon.com: Industrial & Scientific
Magnetic Base with Fine Adjustment and SAE Dial Test Indicator with 0.0005: Resolution (half a thousandth), 1" Travel, Accuracy 0.001" per 1" Mag Base MBDI: Amazon.com: Industrial & Scientificwww.amazon.com
and this:
Mercedes Wheel Bearing Service Kit - Timken 1409810305
Mercedes Wheel Bearing Service Kit - Timken 1409810305www.fcpeuro.com
You can get cheaper dial indicators than the one shown but bottom line if the OP wants to resolve this for good all he needs to spend is about $100.
Buying only bearings for the one, problematic, side would be even less but would be the minimum replacement parts. None of us have seen the inner bearing on this car so that is why it would be dumb to think of this all in terms of just the bearing we can see in the photos, right?
Agreed. Plus a new axle seal.Just put new bearings in the old hub.
