1 - 19 of 19 Posts
Hello,
Mog goes too slow in 4WD mode on the sand.
And Diff lock is not engage. When i pull differential lever to 3rd position (the top ) it is click and doesn't stay there and back to 4WD itself into the lower echelon
Note : om352 Engine
1995 MB 1224AF Doka
I don't know Mogs- but that's like a 2L engine isn't it? Depending on load, I'm surprised it moves that well.
2001 W163 ML270CDI / 2006 W164 ML500 / 1986 U1300L Unimog
Granny shiftin', not double clutchin' like you should. 😜
1963 Unimog 404
That's moving pretty good for being a 404 and being on loose sand. It's this truck new to you? You only have, at best, 80hp moving at least 8,000 lb truck.
Discussion Starter · #6 · (Edited)
Diff lock is not engage. When i pull differential lever to 3rd position (the top )it doesn't stay there and back to 4WD itself into the lower echelon
om352 Engine
Yes I am new owner. I am very novice at this
It's om352 engine. I think 6L
'76 1300L,HE351CW,H15P Winches,Konis,Hydraulics,All Gears,10mm Plungers,Aftercooler,Lots of Littles
Nothing about this post makes any sense to me.
C.
Reactions: Karl K
1991 1250L Doka Unimog, 2002 ML320
It seems to be driving well. Are you saying that it is popping out of "differential lock"?
Chas
Unimog Moderator
His 404 isn't stock, it has an OM352 in it: Help for 1974 Unimog 404
In that lighter chassis, it should move along pretty well especially if the axle gearing is stock 404.
The linkages for the lockers on the 404 are mechanical, they probably need lubricated, and adjusted.
Discussion Starter · #11 ·
Yes. All you wrote is correct. I'll check lubricated.
Thank you.
1963 Unimog 404
My apologies. I didn't read the OM 352 part. In either case, it looked like it was moving fine, but a video doesn't tell the whole story. Locked diffs will be more easily felt than seen in this scenario. Let us know what you discover!
By the way, congratulations on the new unimog! And welcome to the forum.
U-1300, 3 ea 406, 3 ea 404, Haflinger, 2 ea LMTV.
If the Diff Lock "gears" are not aligned when you lift the DiffLock lever, you will feel a spring, as you did. Hold the lever up and drive some. When the gears align the lockers will engage and will then not pop out of lock.
Nice truck!
Bob
Discussion Starter · #14 ·
Thank you @MicMoor77
The video below my problem. I drive slow and try engage diff lock , and drive little more fast with other shift 1. 2. 3.
So I try hold it up to 1 minute . But when i release it it goes down again
1963 Unimog 404, 1961 Unimog 404
It is normal for the detent under the 4wd lever to wear out and not hold it in the differential lock position, I dont know that there is a way to replace or repair it so you may just have to hold it in the lock position.
1957 Unimog 30, 1999 E320, 2004 E320
I has a 411 with a similar issue, the top detent had a worn grove and the ball has nothing to really engage with and wouldn't stay in place unless you held it.
U1000Ag
A bungee cord to the rescue - would not be the first time :)
Reactions: NhBen
1963 Unimog 404
Your lever should look like this:
Road surface Asphalt Guitar accessory Grey Black-and-white
You can check the bottom of the lever to see how worn the holes look.
Automotive tire Bicycle chain Tool Automotive lighting Bumper
The detent has a tendency to get stuck if it has old grease or mud stuck in it. Make sure it is returning to the up position. Mine is welded on and appears to be unserviceable. I just stuck a pick in the hole on the bottom and cleaned it out while spraying WD-40 inside.
Automotive tire Bicycle part Rim Composite material Gas
Automotive tire Road surface Wood Asphalt Grey
Automotive tire Road surface Grey Wood Asphalt
Öyle camdan bakarak birşey anlayamazsınız.
2WD çekişle patinaj yapacağı eğimde bir yer bulun, başka birisi dışarıdan yandan çeksin.
Lever'i elinizle yukarı pozisyonda tutarken dahi diff lock gerçekleşti mi, ondan dahi emin değilsiniz.
Yani "kol yukarıda durmuyor" sorusu 2. soru olmalı aslında. 1. Soru siz kolu yukarıda tutarken kilitliyor mu?
Dediğim gibi ya bir eğimli alanda deneyin, ya da aracın tekerleklerini çapraz askıya alın, öyle bir bakın.
1 - 19 of 19 Posts
