G
Whats up Frank. Thanks for the response about th filters. i have one more Question for you. Exactly
whats needs to be done to make 19' AMG CL's to fit CLK's? How much will it cost to make them fit? I really liked your setup with th CL's. Are there any negative issues with machining the wheels to make them fit on a CLK? THA
G
Discussion Starter · #2 ·
I only tried fitting the 8.5's so if you want to go 8.5 all around....
You would need to buy the CL wheels, obviously,<br> mount 235/35/19's<br> <br> Instead of getting the 10 mm Lorinser spacer which need machining, get four 5 mm H&R spacers and place them upfront and two 15 mm H&R spacers for the rear.<br> <br> These snap into the wheels perfectly and are hubcentric. That's all you need ! Good luck
G
Discussion Starter · #5 ·
What kind of spacer do I need in order to fit 19x8.5 front and 19x 9.5 rear Drew? (CL 1 Pcs) TIA
G
Discussion Starter · #6 ·
To get the right offset. you need 10mm spacers so two 5's to make the wheel clear the wheel well.
