'99 E300 Turbodiesel
Is there a difference between the stock S and C class wheels? Load capability maybe? They look the same when comparing on Tirerack. I am looking for some replacements to put on my wifes 99 E class and I need to know if the S class wheels are a direct fit. I don't want to go much bigger or wider.
BenzWorld Tire & Wheel God
c-class wheels have a lower load capacity and use 12mm lug hardware
s-class wheels ha...
s-class wheels have a higher laod capacity, lower offset and use 14mm lug hardware
CLK55/G500/E55/ML55/etc.
Re:
Luke, you know this but you slipped: S-class have higher offset (for W220). That is, higher numerically... ET44 vs. ET35, for example on many rims.
-s-
oops !!!! wasn't reading what I typed ... you are correct sir .... 44 is higher than 35
