im looking at buying a 92 e300 in great shape but I rolled it out from the garage today and it was leaking a yellowish oil. I think it is anti freeze but Im not sure cause i cant tell where its dripping from. it was sweet to the taste, any ideas?
95 E320 Coupe, 11 E350 4Matic P2
Yellowish oil sounds like water and oil mixing... Maby you have a blown head gasket, check your dip stick if it's the same color you know what to do.
1992 W124 300ce sportline , {1992 W201 2.6 (totalled) }
if u use MB coolant - it is yellowish in color and looks like oil and it is sweet to taste too...
it could be ur waterpump - if it leaks from 1/4 way from the front underneath the engine then it is ur water pump...
However do check your oil too and coolant - headgasket as suggested earlier...
1989 300E
Find out exactly what it is!
Keep in mind that a head gasket and a water pump replacement will cost you a lot of money so make sure of what it is leaking before you buy this car! It may be that a water hose is not tight or there is a leak in a water hose...no big deal, but you will want to know now while it isn't your problem then to buy it and find out you need to drop a grand into your "New" car!
Brian
Discussion Starter · #5 ·
thanks for all the help. I still haven't a good opportunity to drive over to the car and look at in great detail. Im thinking it would be a good idea just to get a pre-buy inspection I know of a really good place here in town. But at least now I'll have an idea going in what I'm dealing with, thanks again.
