BenzWorld W140 Host
W140 S 320 L & R129 500SL
Yesterday i sent the S320 for a service.Everything went fine.I even ask them to check the gearbox etc etc.So they did and all the fault is corrected.
But the only problem they did not slove is when driving the car at 100km/hr, you will feel a slight jerk till the 120km/hr mark.After 120km/hr passes ,it runs smoothly.
So what can be the problem?
Thanks in advance.
S600L
Could be your tyres![:)]What make and size are you running?They may just need re-balancing as they 'go off' a bit when they wear or any weights fall off[;)]
anything i want
deathrattle - 5/3/2005 12:16 PM
If you feel a slight jerk at 100kph maybe it's because you are wearing your hat back to front or your shoes don't match your trousers.Presumably if you no longer feel a jerk at 120kph it's because your mind is fully focused on the road ahead and you lose your sense of self conciousness.Hope you start to feel good about yourself soon.[;)]
now thats some funny stuff right there[:D]
ok it's 2 things..1 injectors need cleaning, (your dealer can do that)2 when your at the gas pumps put the good stuff in, ...
