1 - 15 of 15 Posts
Whatever happened to our SLK FAQ? I thought Brian or Bruce or one of our more active old timers had been compiling great info for us... I was looking for info about how the spark plugs work, and the tranny works. Brian gave me a "Everything you wanted to know" book on my SLK and I was pulling apart my den looking for it... I know I've got it but my wife probably packed it into a box or chest. Bummer.
And I have a slight squeeking noise coming from the roof. It's only very minor and happens only occationally. I happened across this interesting suggestion of using Petrolium jelly on the rubber... Thoughts? Will I just make a mess?
http://www.automotiveforums.com/t295878-slk_vario_roof_squeak__how_to_stop.html
06 corvette coupe
I'm not sure if vaseline would hurt weatherstripping over long periods of time. wouldn't hurt to try short term to at least diagnose your problem.
2002 SLK 32 AMG
I would use something made specifically for rubber weatherstripping, like "303 Aerospace Protectant" or some similiar product (without silicone). Vaseline is obviously petroleum based and I think it could damage the seals.
01 SLK 320 MT6
rbridges - 4/26/2005 3:51 PM
Adult store should have a lubricant that is safe for rubber, but i would try MB Dealer first. [:D]
Very clever Kirill .. I didn't think of that. I have a little squeaking sound (just a very little) when it is very warm weather outside -- just when I pull off and a few minutes thereafter. I figure the material is expanding because of the heat; it is not a real problem for me. I use Amor All on the rubber sealers.
Kirill - 4/26/2005 4:36 PM
01 SLK 320 MT6
kmrotterdam - 4/26/2005 5:52 PM
I had exact same problem - dealer applied something to seals and it was gone.
I suggest you use 303 instead of Armor All it gives you a better protection, also there is a possibility that Armor All can damage rubber\plastics.
303:
http://www.303products.com/store/moreinfo.cfm?Product_ID=29&CFID=1324240&CFTOKEN=64610992
1999 SLK 230
16falcon - 4/26/2005 3:57 PM
I agree petroleum-based vasoline is bad. Why no silicone?
SLK 230 yellow
Here ya go....
SOLVE YOUR SQUEAKY ROOF PROBLEM:
Following is a copy of MERCEDES TECHNICAL SERVICE BULLETIN #TSB AF77.30-U-1200AG; Squeaking and tearing noises at all Vario roof seals.
Remedy:
1) Clean contact points on seal on both sides.
2) After cleaning, apply special lubricant to dry seal and allow to soak in for approx. 20 min.
3) Open and close vario roof a number of times.
4) Remove excess lubricant.
Part number for special lubricant is 001 989 50 51.
IF YOUR CAR IS STILL UNDER WARRANTY THE DEALER WILL PERFORM THIS SERVICE FOR FREE.
[;)] FR///
2002 SLK 32 AMG
DickB - 4/26/2005 7:30 PM
Just what I have read in the "detailing and car care" forum. Silicone in products like Armorall is supposed to be bad for plastic, vinyl and rubber parts (including tires). Do a search on "silicone" in that forum and you will see it is discussed a lot.
SLK 230
$21.00 at the deler.
SLK32AMG
16falcon - 4/26/2005 10:32 PM
Honda has recommended not using Armorall type products on the vinyl dashes for years. Leads to cracking. I equate it to cooking your dash with Crisco.
1999 SLK 230
Oh. Well, I wouldn't use Armorall for this but I have used spray silicone lubricant such as that made by 3M. It is recommended for exactly this type of application. In fact, IIRC it was recommended by the car manufacturer of one of my previously-owned convertibles.
SLK 230
AMPM - 4/27/2005 2:21 PM
I've just been to my local (UK) dealer. They quoted me £26 which is roughly equivalent to $47... owch! Someone else said try WD-40. Does anyone know whether this would be any good?
01 SLK 320 MT6
Bazzle - 5/19/2005 3:19 PM
Dont use wd40 .
It is kero based and will evap away .
I told you guys "rubber safe lube from Adult store" [:D]
Just get the thing from dealer - or try finding it online for less. Or Aerospace 303
1 - 15 of 15 Posts
