Hi, I have a 1993 400e with the 4.2 litter and I've come to a roadblock and don't know what to do. I stripped out a bolt hole when replacing the timing tensioner and I ended up drooling and re-threading it and I don't know if I made the hole a little bigger than need be, or what but I used a heli-coil and right now it's torqued to spec but it leaks major oil and currently is undrivable, so obviously it's not sitting flush. I've taken this apart 5 different times messed with it, put back together and failed every time.... What should I do? Fill that bolt hole in (w what) and start completely from scratch? I don't have the funds to take it in and have done so much to the lady with countless invested hours... any help is appreciated, as my mental state and back can't keep at it.
Thank you
David
Thank you
David
