2003 E500
Anybody know off hand what size headlight bulbs are used for a 2003 E500?
Actually for all the white bulbs in the front end of the car....
I want to install those super bright white type of bulbs as I don't like the yellowish look my current bulbs give off, and I don't want to upgrade to HID as I think it would cost too much and would be a pain to install (unless someone can prove me wrong). Thanks in advance!
Oo == oO 98 E320
Your owner's manual will tell you which size bulbs fit. As you will find via search in the 210 forum much discussion about headlights. I replaced my stock bulbs with sylvania silverstar's. They were about $40 for the pair; the brighter/whiter light gives about 30% more distance & some additional width. My foglights are almost unnecessary now. I only replaced the low beams as I have adequate light with the highs on.
'01-E320 & 02-ST2
You first, however, need to know if your car has halogen or HID lamps. Both were available, and both use different systems (and bulbs!) to light the road. ;)
Once you know that, we can make suggestions and recommendations, but that's the first step.
