no...what I'm saying is, the rule of thumb of a good working AC system,
is the ability to pull down 45 degrees below outside ambient, in a car.
if it's 100 outside, it should be able to have 55 degrees at the vents.
the atypical "ice cold air"
on a house system, my HVAC friend tells me, 25 degrees below outside,
because a house is much larger, and more airspace to pull down
so if it's 100 outside, it should be able to do 75 inside
these are general rules of thumb, not hardfast
if we see that, we don't go digging around for problems...cuz it's working.
the AC won't dispense the same temp air regardless of outside ambient,
there are humidity, airspace factors, and what the inlet is set to affects it,
is it on recirculate, or pulling in 100 degree outside air to treat ? like that...
